Re: trouble, now what
Posted by Janicholson on February 09, 2008 at 18:58:15 from (66.173.50.135):
In Reply to: trouble, now what posted by tooltime on February 09, 2008 at 18:05:17:
340s have a light feel to the clutch.
From the picture I know it is on concrete.
With the engine off-----
Block down the clutch pedal (or clamp it down) and put it in high gear. Now roll the tractor forward and back. if there is little resistence, it is probably OK. Now have some one start letting out the clutch while pushing it forward and back (engine off)
If there is a point at which the tractor stops moving as the clutch is engaged, I think it is OK.
Aim it out of the garage by pushing it. remove the wire going to the coil from the key.
Put it in first with the clutch down and crank the engine. if it cranks you are good to go. Put it together and try it. Be sure to keep your hand on the key to stop it if it keeps moving. Good luck, JimN
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
