Re: 504 Hydraulics (picture) Karl F, this is for you...
Posted by karl f on February 09, 2008 at 22:41:57 from (172.162.187.54):
In Reply to: 504 Hydraulics (picture) Karl F, this is for you... posted by Charles Todd on February 09, 2008 at 21:51:32:
third party image
the clearance you need is between the crank and the front steering/radiator support. i tried to attatch image with arrow and some coloring. measure all available space you have LxWxH. you should have no problems with hoses, it will be a pump and rigging a good support for it that might be a challenge--it needs to be fairly centered to the crank. the ford setup is nice there's a good hollow space where the IH is solid. there are enough makes of pumps out there that one might work for you after all. then you need to add a reservoir to the loader frame or on the tractor somewhere. that would be the least complicated way to supply oil to the loader. make sure if the loader is disconnected you hook the pump hoses in a loop so it doesn't build pressure or run dry, which means the engine needs to be off for that step.
glad to start a brainstorm!
karl f
