Re: My W6 Won't Run
Posted by Red Mist on February 10, 2008 at 06:50:33 from (208.61.169.38):
In Reply to: My W6 Won't Run posted by TONYR on February 09, 2008 at 13:27:44:
Well, it sure sounds like you are running lean for some reason. If you are positive everything you have checked thus far is okay, it is time to check your manifold for cracks and check your manifold gaskets for leaks - especially between the manifold and the head. Get it running and spray around manifold and head with WD-40 to see if sound of engine changes....
mike
