Re: FARMALL H HYDRAULICS
Posted by Janicholson on February 10, 2008 at 15:27:47 from (66.173.50.24):
In Reply to: FARMALL H HYDRAULICS posted by Steve Driscoll on February 10, 2008 at 14:50:19:
Much depends on two factors:
The weight and rear length of the mower, and the size of the cylinder on the 3point.
Four recommendations.
Increase the area of the cylinder by 50% (A= pi X radius squared). This is probable easiest.
Use a spring balance to remove apparent weight from the mower. How to attach, and where to anchor for assist is a bit harder.
Attach a hydraulic pump to the belt pulley mechanism (I recommend a pump that would be next to the drive, and powered by a cog belt drive to eliminate maintenance)
Or use a front crankshaft driven live power pump.
(I think there are images of several in the archives on Hs) JimN
