Re: Super C - can you remove the timing gears withough pulli
Posted by tractorsam on February 10, 2008 at 17:12:42 from (71.7.203.35):
In Reply to: Re: Super C - can you remove the timing gears withough pulli posted by El Toro on February 10, 2008 at 16:41:00:
Many thanks for the reply. I already have everything apart, I'm just looking at the space behind the crank gear (more or less non-existant). I don't really have a problem with pulling everything apart, was just hoping to avoid the extra work as I haven't got a suitable hoist for removing the engine to change the gear on the crank. Just wondered if anyone had managed to pull it without removing the crank. Spent all day making up a puller to remove that front pulley and managed to do it with scrap metal I had lying on the floor. Many thanks, tractorsam
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
