Re: Front Drive Hydraulics on a 504 (pictures)
Posted by Charles Todd on February 10, 2008 at 19:24:53 from (205.242.95.139):
In Reply to: Re: Front Drive Hydraulics on a 504 (pictures) posted by Steven f/AZ on February 10, 2008 at 18:47:12:
Ok, I need 12-15 GPM and would like to either use belt or chain. Chain seems the strongest, but has issues with maintenance and transmits harmonics (vibrations). This cogged belt you speak of, you mean like a poly-chain, with teeth on the pulleys and the belt, like on servo drives?
Where would I take the input (pressure side) from? Where would I send the excess (return side)? The only hose I know of is the output from the main pump feeding the tractor and remotes.
I liked the chain setup on the picture posted above.
