Re: Bent push rods, bad gasket, and 8 hours later......
Posted by Brownie450 on February 11, 2008 at 03:40:37 from (216.51.158.220):
In Reply to: Bent push rods, bad gasket, and 8 hours later...... posted by 1fortyfanatic on February 09, 2008 at 19:42:53:
I've had good success soldering radiators with Kester acid core solder. CLEAN the leak area WELL & use a small amount of flux. I've seen lesser qualities of solder tried on a radiator repair, & they make a mess. Clean the area well with hot water with baking soda stirred in after soldering. Run some soda water inside the radiator also followed by a couple of flushes. This neutralizes any acid left behind.
