Re: Can't work on the ole tractor blues
Posted by Janicholson on February 11, 2008 at 06:49:27 from (199.17.6.122):
In Reply to: Re: Can't work on the ole tractor blues posted by GeneMO on February 11, 2008 at 06:29:14:
With the top off (in my opinion) it is a tossup as to whether to take out he bulls. With solvent it is pretty easy to just rotate the gears and rinse things as they are, Putting a rag under the bull gear and letting it pull through would get any material on the run. Then drain and dry befor putting it back together. My reasoning is that there is not much more revieled with them out. JimN
