Charles Todd said: (quoted from post at 20:24:53 02/10/08) Ok, I need 12-15 GPM and would like to either use belt or chain. Chain seems the strongest, but has issues with maintenance and transmits harmonics (vibrations). This cogged belt you speak of, you mean like a poly-chain, with teeth on the pulleys and the belt, like on servo drives?
Where would I take the input (pressure side) from? Where would I send the excess (return side)? The only hose I know of is the output from the main pump feeding the tractor and remotes.
I liked the chain setup on the picture posted above.
The chain drive above works well for that person, but it is used at low speed (1/2 throttle or less) and it is in town so they don't have to contend with any dust, mud, etc.
Personally, If I were to put a separate pump on for the loader I would purchase a reservoir/tank just for that system and keep it separate from the tractor hydraulics...
Another thought I came up with is to check on the possibility of an optional pump for the tractor... some had choices of around 9 GPM, 12 GPM and I think there was a 15 GPM pump option too. I'm not sure if that's a possibility on a 504 though.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
