You need to remove that inspection plate under the belly pump and try to asertain where the leak is coming from, a line, a fitting or the shaft seal that drives the pump. If it is a shaft seal the pump needs to be removed so you can change it..not that hard a job if you feel limited in your mechanical ability but getting the pump out needs another helper or a support jack stand. The shaft seal has a flange that turns off, pick out the old seal and install a new one, replace the flange and then reassemble pump..there are other scenarios that could be in there as well, you'll have a better idea when you get a good look.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
