As easy as pie: The timing mark is static timing for the point opening when at cranking speed (or hand cranking) It is TDC. The timing with a light requires a degree wheel or Geometric calculation of circumferential distance to mark the correct location of the timing when running (they have advance mechanism) Magneto systems in Farmalls do not have advance mechanisms except the impulse coup[ling, so they are fuill advance upon starting. JimN
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
