Re: Long Time Question on Super M
Posted by karl f on February 11, 2008 at 12:22:55 from (64.83.221.111):
In Reply to: Long Time Question on Super M posted by Tom43 on February 11, 2008 at 08:46:01:
i think the specs for the distributor begin to list a small amount of advance at only 250 rpm. i believe that it's in distributor rpm (double for crank), have to look. also i think there were a couple different pulleys with a different number of marks...it's possible you looked at the right info for the wrong pulley and the result is about 15 degrees off. there may be other pulleys that fit than the 2 originally optioned for the engine, adding to more marking confusion. plus could be the "wrong" or field changed over distributor.
question for others: what changes did the firecrater kit do to the advance timing curve?
karl f
