Re: Crack in my crankshaft
Posted by old on February 11, 2008 at 14:52:40 from (4.244.217.52):
In Reply to: Crack in my crankshaft posted by P and R Pete on February 11, 2008 at 14:33:16:
If in fact the crank is cracked nope it can't be fixed and hold up very long. Believe me you don't want it to brake when the engine is running or you might be looking for a complete engine instead of just a crank shaft. Now then what tractor do you have?? I might have a good used crank on hand. Or you can also buy a crank shaft from this site and or value bilt
