Posted by lee m cramsey on February 11, 2008 at 16:36:21 from (72.240.146.240):
In Reply to: What Is Going On Here? posted by Allan In NE on February 11, 2008 at 13:34:48:
Allen, I had the exact same issue when I put the M motor in my 400 so I could use it. It is just the spacers like everyone else said. I took the fan and spacer off my 400 motor and it line up fine. Not too difficult. You could look for 400 parts if that makes it easier to find. Lee
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
