Re: What Is Going On Here?
Posted by D Slater on February 11, 2008 at 18:36:28 from (72.65.139.26):
In Reply to: Re: What Is Going On Here? posted by Damp;Dservice on February 11, 2008 at 16:56:04:
Damp D service, I wouldn't worry about it. If the tractor is a 52 model it has the correct engine. Engine probably has the same last 3 digits on serial # that tractor serial # has.
On the fan, charr lynn used spacers behind fan with 4 bolt holes that match ones holding fan on with that pulley set up. Also used longer bolts with sleeves on them to take the place of IH pump impeller drive studs. This moved fan far enough forward to clear if fan blades were not bent.
