Re: Where to brace this Farmall 504 axle (pictures)
Posted by Charles Todd on February 12, 2008 at 08:23:34 from (205.242.95.139):
In Reply to: Re: Where to brace this Farmall 504 axle (pictures) posted by mkirsch on February 12, 2008 at 05:49:47:
Thank you mkirsch, I did not know what the powertrain can handle. I just thought maybe, extend the sub-frame, extend the hood line... Dreams.
The loader has a 2800lb max capacity at the bucket, 4000lb at the pins. I plan no more than a 6ft bucket of dirt or 4x5 bale (800-1000).
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
