Posted by Bob on February 12, 2008 at 12:52:02 from (69.178.229.154):
In Reply to: Generator Trouble posted by Dean Meyers on February 12, 2008 at 12:16:02:
This is an "A" circuit generator.
You polarize it BEFORE startup by jumpering "BATT" and "GEN" (ARM", if so labeled).
The Ammeter SHOULD show discharge while you are doing this.
Then you START the engine. If NO charge, you can try "full-fielding" the generator by grounding it's "F" terminal. This eliminates the field resistor/switch or voltage regulator from the circuit, and should make it charge as much as it is capable of, putting the Ammeter well over into the "CHARGE" area.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
