Thanks, Bob More detail. I took the tractor down for a new carb, change liquids, fan assembly, etc a couple weeks ago. I took the neg battery cable off for safety. When I brought it back up I polarized the battery as usual. I startd it up and plowed snow for 2 hours at full throttle. It would never charge. With lights on I had 18 amp discharge. I took gen off and checked for loose wires etc. Had an old mechanic check armature and he said it was ok. Put it back on tractor today. Forgot to polarze and ran tractor a few minutes before I remembered. Shut it down and polarized. Brought it back up and went thru the Melville flow diagram with tactor at 1/2 throttle. That's where the amp gauge buried itself on discharge when I put a jumper between the BAT and GEN terminals and also when I grounded the Field. Now, I just tried what you suggested with tractor at 1/2 throttle I grounded the Field. The amp gauge buried itself on the discharge side and remained there until the jumper was removed. Dean
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
