Re: Continuing, Where to Brace 504 Wide Front Axle
Posted by Charles Todd on February 12, 2008 at 13:04:35 from (205.242.95.139):
In Reply to: Re: Continuing, Where to Brace 504 Wide Front Axle posted by Allan In NE on February 12, 2008 at 12:37:47:
Thanks again Allan on the geometery on the wishbone, I was a little unclear on how it actually stabalizes the axle and still provides articulation.
As for duals, I am worried about 2wd, no diff lock, traction. Felt maybe duals would give more surface area to find traction. If not enough, fill all four with water.
As for the PTO Hydraulic pump, it takes up the PTO. I would have to remove it to use a PTO accessory. I did see a pic of an old pump with a PTO output stub comming out of the pump?
Most likely I will just plumb in an open-center-power-beyond valve bank and take the slow cycle rate (12 gpm tractor pump, 45 years ago).
