Re: A, SA, 100 15 steer rim
Posted by gene bender on February 12, 2008 at 20:39:53 from (67.55.226.214):
In Reply to: A, SA, 100 15 steer rim posted by couv on February 12, 2008 at 19:16:43:
The rims you now have have the three places where they bolt to the center correct. You need the 3x15 standard rim for the regular A. Now going to the 15in wont be a problem for your blade set-up. You can grind the center out of any 15in rim that will fit over the cast centers then weld three brackets to match. What size tires do you want to run. I have rims that will bolt on.
