Re: brakes - 2656
Posted by Allan In NE on February 13, 2008 at 04:24:44 from (148.78.243.26):
In Reply to: Re: brakes - 2656 posted by bc on February 12, 2008 at 18:13:28:
They don't work anything like a car.
The mechanical "actuator" works from the inside out in a "swealing" fashion against it's component's total "thickness" and there is only a certain amount of travel no matter how many "washers" you put under that adjustment nut.
This "total thickness" translates into pedal travel and is adjusted by the number of shims at the outer cover. The ballnut is then used as a "fine-tune" adjustment.
The thickness of just one shim makes one heck of a lot of difference.
Good luck. Those old bolts are probably gonna be rusty and hard to get out, but it's a fairly simple procedure.
Also, don't throw those shims away! If you ever have to replace the discs with new, you'll never get the stack together without the shims being there again. :>)
Allan
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
