Re: Super A - convert magneto to coil
Posted by Janicholson on February 13, 2008 at 06:22:43 from (199.17.6.122):
In Reply to: Super A - convert magneto to coil posted by Michael C in TN on February 13, 2008 at 06:11:12:
I do not think there is an electronic module to fit a Magneto. They are, in most cases designed to replace the breaker (points) plate in a distributor. The reason is probably because there is an issue with the impulse coupling and lack of centrifugal advance on the mag setup. The best option is to get a IH distributor for the SA then convert it to electoronic. (I think they make 6 volt electronic modules, so it might be possible to avoid the 12v conversion as well. Be sure to check the bushing wear in the distributor, as well as the advance springs and cam advance motion, some are stuck/broken. Good luck, JimN
