Re: Busted loader fix ideas
Posted by Janicholson on February 13, 2008 at 06:37:04 from (199.17.6.122):
In Reply to: Busted loader fix ideas posted by Jeef on February 12, 2008 at 18:40:39:
Brownie 450 is giving good advice. If the pivot opint is moved rearward, the geometry will likely be made worse, or not work, or allow excess force to be applied to the rams on the bucket , bending them.
I would get solid measuremants (vertically and length) for the original location of the bushing.
Then I would trim off the material that is torn from eash side evenly such that I had good clean metal, square to the new extension to be made.
I would use heavy wall rectangular tubing (or round if it is round arm material) and make an extension that fits inside the clean arm hole and has the new bushing inside it already. Then I would make two plates to fit on both sides of that, to fill it out to the original width. Welding this to the frame arms, and the new extension, finishes the extension. Putting the bushings in the added part before welding saves aggrivation. JimN
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
