Re: Starter dragging
Posted by Ron-MO on February 13, 2008 at 13:42:34 from (63.87.140.3):
In Reply to: Re: Starter dragging posted by Eds on February 13, 2008 at 13:22:00:
You may in fact have a starter issue. Also make sure the mating surfaces where your starter bolts to the engine is clean and bright. I had one recently where that made the difference after wire brushing that surface(s). Remember that that surface is your path to ground, and if your starter has rust/paint/whatever where you mate with the engine it is no difference than having a dirty ground cable.
