Michael...
Posted by Bob on February 13, 2008 at 17:36:52 from (69.178.229.154):
In Reply to: Re: Super A - convert magneto to coil posted by Michael C in TN on February 13, 2008 at 13:08:13:
You are correct in saying that you can feed the output of an external coil into the center tower of the mag's cap, using it as a distributor.
HOWEVER, if you want a "battery ignition" that uses an "off-the-shelf" electronic igntion unit, you'll have to swap to an IH or Delco distributor conversion unit, the install the appropriate Pertronix EI kit.
