Re: Ignition Coil Wiring
Posted by Owen Aaland on February 14, 2008 at 02:07:53 from (65.165.246.161):
In Reply to: Ignition Coil Wiring posted by Duane Eckelman on February 13, 2008 at 17:24:38:
Connect the + terminal to the positive side of the battery and the - terminal to the negative side of the battery.
In a negative ground system the - terminal goes to the points. If you have a positive grounded system the + terminal goes to the points.
