Re: Ignition Coil Wiring
Posted by John T on February 14, 2008 at 08:29:30 from (24.227.192.14):
In Reply to: Ignition Coil Wiring posted by Duane Eckelman on February 13, 2008 at 17:24:38:
As posted, simply match the coil to whichever ground you have i.e. if at Neg ground the coils -wires to distributor and its + receives Ignition Switch voltage. It can still produce a spark if wired wrong but its more efficient if wired correctly.......
John T
