Posted by Wayne in MN on February 14, 2008 at 20:25:30 from (66.188.164.204):
In Reply to: Farmall M Belt pulley posted by Zach Bouchard on February 14, 2008 at 20:11:45:
Remove the pulley unit to clean. It is lubed from the transmission so attempting to clean with diesel will mix with the transmission oil. The seal can be removed without removing the entire unit. Remove the cap screws & tap on the backside of the pulley flange. Remove the capscrew on the end of the shaft & slide the parts off. Reverse proceedure for installation. I like to use a VERY thin application of silicone sealer on the metal shims when re-assembling.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
