Re: Does anyone have the size of the SC belt pulley?
Posted by Hugh MacKay on February 15, 2008 at 09:22:39 from (209.226.106.24):
In Reply to: Re: Does anyone have the size of the SC belt pulley? posted by Larry in GA. on February 15, 2008 at 08:45:48:
Larry: The belt pulley gear box is supplied from the transmission via the oil slinger gear. You'll notice the transmission requirments are about 1 quart more when eqipped with pto and belt pulley. You can pour oil in the belt pulley fill cap, however there is a overflow back to transmission and if you try to over fill the pulley gear box, the excess runs to transmission.
