Need H Water pump bearing spacer?
Posted by dep on February 15, 2008 at 14:55:22 from (64.12.116.73):
I just assembled the water pump on my H and discovered that it's hard to turn once the nut is tightened down. The book says the probable cause is that the bearing spacer is too short. I called around but that part is discontinued. Anyone else have this problem? What is the correct length of the spacer? Maybe I could make one up.
