If you used the old spacer over I doubt it"s the spacer causing you the problem. Was the pulley pressed down over the center tube or tightened down with the nut to draw it down. The nut stops at the correct height to keep the pulley from bottoming out to hard on the felt washer under the pulley. Or possibly the pulley was completley torn apart and the bottom pulley groove wasn"t pressed back on far enough. I have built a lot of those pumps and have never had to adjust a spacer.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
