F-20 HEISLER OVER-UNDER DRIVES???
Posted by BIG BORE 20 on February 16, 2008 at 09:39:52 from (12.192.31.234):
Has anyone seen or heard of a Heisler over-under drive for F-20"s. This would give you 12 speeds forward and 3 in reverse. I have two F-20"s with just overdrives 8 speeds, But have never seen a over-under. I had a man tell me he had a friend that had a over-under on an F-20. Is this fact or fiction?
I put a overdrive in a F-20 that had the fast 3rd gear. When you put it in 3rd overdrive that tractor would run 25 MPH. That is a white knuckle ride on one of those old tractors I"m here to tell you.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
