Re: smoking hot brake---340IH
Posted by Janicholson on February 16, 2008 at 16:06:05 from (66.173.50.34):
In Reply to: smoking hot brake---340IH posted by tooltime on February 16, 2008 at 16:01:46:
THe three return springs on the perimeter of the plates can be weak. The adjustment could be too tight, the ball tracks can have dents in them locking the balls, and the friction material can be too grippy causing self application. Backing up 2 feet releases locked brakes. I would check the ramps and springs first. This type of brake is not the finest setup in the world. But live with it we must for now. JimN
