Re: smoking hot brake---340IH
Posted by tooltime on February 16, 2008 at 18:59:58 from (66.103.166.92):
In Reply to: Re: smoking hot brake---340IH posted by Janicholson on February 16, 2008 at 16:06:05:
I JUST GOT BACK IN FROM SHOP, I REMOVED THE BRAKES AND WOW, THEY ARE WORE , LOTS OF BRAKE DUST INSIDE COVER, ALSO I NOTICED THAT THE SHAFT LOOKS A BIT WORE WHERE BRAKES SIT, BRAKES HAD WEAR MARKS ON STEEL TEETH ALSO, THE ACCUATING ASSEMBLY LOOKS OK, IM NOT SURE WHATS CAUSING THIS, I PUT THREE NEW BALLS IN, NEW SPRINGS, AND NEW BRAKES, HOWEVER THE FACE THAT THE BRAKES BUTT UP TO ARE VERY PITTED AND NOT SMOOTH,COULD THIS CAUSE THAT , WHERE WOULD I FIND PARTS TO FIX THIS KIND OF ISSUE, THANKS,jIM
