Posted by Janicholson on February 18, 2008 at 08:57:51 from (199.17.6.122):
In Reply to: SUPER M MISSING posted by CHIEFEAVES on February 18, 2008 at 06:46:16:
Use an insulated pulg wire pliers and pull the plug wire loose from #3 while it is misfiring. If, as you pull the wire farther from the plug terminal (do not pull it all the way off, just increase the gap to about 3/8"), it starts to fire, and cleans up its act, Change that plug to a different cylinder and start over. If that misfire follows the plug, it is a bad plug. If the mis stays in the cylinder, and comes back the same way, I would do the manifold leak check, a compression check, and a cylinder leak down test. Getting to the real problem is the key. Keep us informed on outcomes. JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
