Re: b250 hydraulics
Posted by JimB2 on February 18, 2008 at 09:17:00 from (99.241.179.24):
In Reply to: b250 hydraulics posted by buggsy on February 17, 2008 at 20:01:22:
Hi Buggsy, does your 250 have the old style 3pt hydraulic control lever which has 3 position lift, hold and drop? If so try the following test, lift the 3pt implement and close the isolation valve (which is the T handle valve in front of the seat), let 3 pt control lever back to hold position, if 3 pt arms go down then the lift cylinder is probably leaking. If 3 pt arms stay up then problem is in 3 pt control lever, possibly the hold position of the control lever is not adjusted properly.
JimB
