Re: farmall m manifold studs
Posted by Red Mist on February 19, 2008 at 07:07:17 from (208.61.169.122):
In Reply to: farmall m manifold studs posted by lbm on February 18, 2008 at 17:12:47:
John, Andy and Tractorman are all correct. They are, indeed, coarse threads on one side and fine threads on the other end.
The 7/16" (2.25" long), started with M serial number 41346 - part number 63459D.
From serial number 501 thru 41345, they were 3/8" - part number 45223DA.
Both showing still available from your friendly Case/IH dealer. mike
