Re: Question For Those With 3-ph On An H or M
Posted by MN Rick on February 19, 2008 at 14:39:29 from (71.210.143.35):
In Reply to: Question For Those With 3-ph On An H or M posted by Red Mist on February 19, 2008 at 14:29:25:
I'm not real familiar with the single cylinder ones, but it occurs to me that if you arent lifting real heavy implements they should be fine. I just took a dual cylinder one off of an MTA. Before I removed it, I hooked it to a 5-16 semi mounted plow just to see how it would behave. Picked it right up, but could'nt let the clutch out gentle enough to keep the front down. I'd think that for back blades and the like a single cylinder should be fine. By the way....that Super runnin better?
