Re: Question For Those With 3-ph On An H or M
Posted by CNKS on February 19, 2008 at 17:52:57 from (216.144.104.128):
In Reply to: Question For Those With 3-ph On An H or M posted by Red Mist on February 19, 2008 at 14:29:25:
There is a lot of overkill built into Saginaw -- but your tractor will wear out before it does, and Farmalls are not known to wear out. Overkill because it is listed for the H-450, will work on a 560 and later. A slightly cheaper Saginaw is made for the C, it will fit the others too, uses only one cylinder, I don't know if you can use the original drawbar on it or not, since the C has another type that does not interfere at all with the hitch. As to strength, I have a cheaper no name on my M with very light cat 1 arms, the way I have used it it should have bent by now, but it hasn't. Sounds like the salvage yard ones might work for you. Also Mike at Steel Wheel Ranch sells another brand, I forget what it is. It has its own drawbar, uses one cylinder, considerably cheaper the Saginaw. Worksaver is likely OK, I did not get one for my C because it uses the front arms and a rod, H uses a cylinder.
