Re: clueless on my Farmall super A
Posted by P and R Pete on February 19, 2008 at 18:16:41 from (207.7.181.33):
In Reply to: clueless on my Farmall super A posted by blksvt04 on February 19, 2008 at 17:23:39:
Howdy.
I happen to have a couple of pics. Here's the side of my oil pan- you use the two petcocks to check the oil level. If it comes out the upper, you're good. If it doesn't come out the lower, you need to add some.
The drain plug is JUST out of view, screwed into the rounded thing on the bottom. Mine has a threaded plug that has a square 1/2" extension to put a wrench on. It's at the lowest part of the pan.
third party image
The new oil goes in the tube under the cap with the pointer. The air cleaner is the taller one to the right. You can follow it down through the hood to a canister on the left side of the engine. The cup that needs oil is held onto the bottom of the canister.
third party image
