Re: Question For Those With 3-ph On An H or M
Posted by Hugh MacKay on February 19, 2008 at 19:15:36 from (209.226.247.142):
In Reply to: Question For Those With 3-ph On An H or M posted by Red Mist on February 19, 2008 at 14:29:25:
Mike: I can build you a draft controlled hitch, but it will cost you $4,000. I trust that may be a bit pricey.
