At the very bottom of your engine is the oilpan. It has the two valves on the side. At the very bottom of the oil pan is your drain plug. It may be a hex, it may be square.
Your filler is the cap that was pointed out in a picture down below. IF you peek down under the hood, you will see that it goes into the valve cover, which is at the very top of the engine.
It will take about five quarts for a fill.
The aircleaner, the other thing with the taller pipe that comes up through the hood, is on the left side of the engine, and has a cup on the bottom of it. The cup comes off by loosening the large thumbscrew on the band that holds it in place. empty the cup, clean it out and refill it to the line. It won't take a whole pint of oil.
You said it doesn't have a filter in it? Please put one in. NAPA stocks a Wix filter that will fit. Maybe somebody will chime in with the number. To replace it, remove the bolt from the top of the filter housing/cover (you have a picture of that, too). It's longer than the cover is tall, and should have a copper washer/crush gasket at the top when you remove it. Then the cover will lift right away. The new filter should come with a rubber gasket. This goes in the round slot you'll see when you remove the cover. I'd suggest you take your pen knife or something else sharp and make sure that the old gasket is not still in that slot. (If you try to put in a new gasket on top an old one, you're almost guaranteed a leak.) Then put the new gasket in place, put the filter in the center hole loosely, tip the cover back into place so that its bottom edge rests on that gasket, replace your bolt and snug it down.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
