Re: 806 Uh oh, oil is overfilling itself
Posted by mhalter on February 21, 2008 at 13:46:22 from (4.225.149.11):
In Reply to: Re: 806 Uh oh, oil is overfilling itself posted by mhalter on February 20, 2008 at 19:06:13:
Okay guys, sorry to bother you again, but I'm stuck. I got the pump off, and was hoping I was going to be able to unbolt the adapter and slide it off the shaft but that doesn't appear to be the case. Do I have to unbolt the timing gear cover and the nut on the front of the pump shaft, then pull the drive shaft out and remove the adapter over the front of the shaft instead of the rear?
