Re: Farmall M oil presure please help
Posted by Steven f/AZ on February 21, 2008 at 16:07:23 from (24.121.155.84):
In Reply to: Farmall M oil presure please help posted by Jossette on February 21, 2008 at 15:03:23:
Holt Alcon said: (quoted from post at 17:00:43 02/21/08) Are the rod bearings also presure lubed?
Yes, everything is pressure lubed - cam, rods, and mains.
Old hot rodder rule of thumb is 10 psi per 1000 rpm. So if you have 20 psi at WOT, you're good to go. At idle you don't need more than 5 psi.
Spec is 70 psi for the relief valve, though. Every H and M I've had will hold 70 psi all day and drop to maybe 50 psi at idle, hot.
