Re: Power steering units which is better
Posted by Red Mist on February 22, 2008 at 16:57:57 from (208.61.161.99):
In Reply to: Power steering units which is better posted by Vito on February 22, 2008 at 16:36:09:
I'd give the slightest edge to the Charlynn because it looks less obtrusive, since it is tucked out of the way under the hood. Both units are excellent performers. The Behlen is less likely to be in your way when the time comes you need to work around the front of your engine. I have a Behlen which came on my SM and I can't complain.
mike
