Posted by James3504 on February 22, 2008 at 19:34:19 from (71.125.98.60):
I'm currently rebuilding the ta, clutch and everything in between. When I got to the main trans. clutch I replaced it with a 6 button hd and new presure plate. When I went to remove the three spring compression bolts in the new pressure plate, the fingers didn't release very much at all. I was wondering if this will work correctly or will I have to have the flywheel machined down to a certain clearance to get the clutch to work or will i have enough adjustment on the linkage rod to adjust this out? Any help or suggestions would be helpful. Thanks.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
