I'm not familiar with this type of swing mechanism but I am a machinist. If the shaft can be removed perhaps the splines could be recut to clean up the wear and make them uniform and a known size. Then a new plate could be made. My experience with water jet parts is that the splines wouldn't be straight enough.Some water jet cuts are better than others but even a few thousanths taper in the splines would lead to fast wear. I think wire edm would be a better way to go. If you can give the programmer a diameter and spline shape (the reason for recutting the shaft first) they should be able to match them up perfectly. None of this is going to be cheap but you probably already know that. Good luck, Ed
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
