Re: Allan: Did You Finish M Power Steering?
Posted by Allan In NE on February 22, 2008 at 20:54:10 from (148.78.243.25):
In Reply to: Re: Allan: Did You Finish M Power Steering? posted by Al in Mn on February 22, 2008 at 17:53:14:
The crank pin is held on and centered by a setscrew.
Take it out, push the crank pin out of the crank, set the pulley on the main pulley (it self-centers), put the pin back in the crank and then replace the setscrew. That's the easy part.
Rough part is that the fan has to be spaced out forward an inch and the shroud has to be trimmed back to allow room for the belt and pulley.
Kind of a bummer. :>(
Allan
