Re: the pics from clueless on a farmall tractor
Posted by blksvt04 on February 22, 2008 at 22:14:29 from (205.188.116.131):
In Reply to: the pics from "clueless on a farmall tractor" posted by jwal10 on February 21, 2008 at 20:45:11:
Hugh MacKay said: (quoted from post at 16:44:33 02/22/08) Cut the crap, you haven't even cleaned the dirt away from the filter canister.
yes i have it was clump up 2, and have already put oil to the recommended level, already got the new plugs measured and installed, new battery installed, the carburator clean, gas tank cleaned, the fuel filter cleaned, all the fuel lines and all is lefted is changin the oil and ill try the oil filter again and yes i have tooken the bolt off and its oily first off and i can move the filter but i swear too you guys, there is no way of getting it off...its welded and painted read in the seams where its conjoined but ill try it again.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
