Re: Allan: Did You Finish M Power Steering?
Posted by Allan In NE on February 23, 2008 at 07:05:00 from (148.78.243.26):
In Reply to: Re: Allan: Did You Finish M Power Steering? posted by TimWafer on February 23, 2008 at 05:09:04:
IH dealers used to sell "extension tanks" to give the belly pump extra capacity.
A round tank that screws onto the fill pipe, which gives the existing belly sump another gallon or two of oil.
Yeah, if you're going to use the live pump, you'll need to use a priority valve in the mix. Plumb the output of the pump to the "in" of the valve and then use it's "EX" (exhaust) port to feed the rest of the system.
If it is the adjustable kind, set it at 3 1/2 gallon.
Allan
third party image
